Activity Forums Avid Media Composer Transfering to another drive
  • Transfering to another drive
    Posted by Rocco Rocco on July 13, 2006 at 10:35 pm
    Avid Xpress 4.6
    OS 10.4
    I’ve been editing on one drive, which contains all the captured material, music, FX etc. [about 100GB] I now want to move only the footage / music / FX that is contained in one sequence (with handles) onto another drive. [about 20GB] I’m having problems doing this in Avid Xpress. (In final cut, I’d simply archive the project, and copy the media etc – but I’m an Avid newbie)
    Do I export an OMF and copy the media and link to the copied media? If so, do I need to create a new project file on the new drive?
    any help appreciated, thanks.
    Rocco Rocco replied 20 years, 2 months ago 2 Members · 2 Replies
  • Michael Hancock
    July 14, 2006 at 11:40 am
    Look up Consolidate in the help files. It will explain in detail how to do what you’re doing.
    A brief overview before you hit the manual: Make a duplicate of the sequence you want to transfer to the other drive. Select it, then go to Clip–> Consolidate/Transcode (I think it’s under clip…it might be under Bin…not in front of the system right now). This will open up your options, such as Handle Length, converting audio bit depth and sample rate, allow you to select which drive you want to transfer the media to. It will essentially do what you want–copy just the media you used, with the handles you specify, to the drive of your choice.
    Again, that’s an overview. Hit up the manual for a more in depth explanation, and post back if you have troubles.
    Mike.
  • Rocco Rocco
    July 14, 2006 at 5:36 pm
    Awesome. Thank you.
