Activity › Forums › Avid Media Composer › Transfering Media from FCP to AVID
Posted by Sascha Engel on April 30, 2009 at 7:53 amDuring the Israeli DocChallenge competition, some of the participants will work on FCP.
The final onlining and subtitling will happen on an AVID system.
In what format the FCP people have to output their films, so it can be handled best in AVID?Most of the competition films will be shot on Panasonic DVX100B in 25fps Progressive.
Some films might be shot in HDV as well.Thanx a lot for advice, for I am not familiar with AVID.
Greetz,
Sascha Engel
Terence Curren replied 17 years, 4 months ago 3 Members · 7 Replies -
Terence Curren
April 30, 2009 at 1:45 pmYour best bet is to purchase Automatic Duck’s Pro export plugin:
https://automaticduck.com/products/pefcp/
Terence Curren
http://www.alphadogs.tv
http://www.digitalservicestation.com
Burbank,Ca -
Sascha Engel
April 30, 2009 at 9:43 pmo.k. but let’s guess, young fcp editors don’t have that.
What file is the best to give?
Quicktime DV Pal 25fps? -
James Beattie
May 1, 2009 at 1:18 amYes, the DV 25 file would work. But I agree, Automatic Duck will make you life better. Worth the money. Think of how long it will take to export and realize the value.
Sascha Engel
May 1, 2009 at 4:13 amHi,
I would like to understand something – I thought Automatic Duck is good, e.g. when you export from FCP to AE and you wanna get all effects and Transitions and other information from one application into the other.
But what difference to I get in this case? AVID does recognize a Quicktime DV-Pal 25fps that comes from out FCP? So, what will be the problem then? When I export a Quicktime from FCP and import it to AE it’s also no problem.
What’s the difference in that case with AVID?Greetz,
Sascha Engel
Terence Curren
May 1, 2009 at 5:32 amYou said in your original post that the “Final onlining” will take place in Avid. From that I assume that you will be doing something to individual shots, like color correcting. If you send one big QT movie, you will have to go in and add edits throughout the QT movie. You will also have to match the dissolves manually. And if there are any composited shots, you won’t be able to work on the elements individually anymore.
With the Automatic Duck approach, all of your shots would be in there separately.
Can you take one movie in? Yes. Is that the best approach when you plan to continue work on it? No.
Terence Curren
Burbank,Ca -
Sascha Engel
May 2, 2009 at 6:51 amMaybe I was not clear enough about what will be done there:
There’s no more colour corrections. The Festival will ad some graphics and logo and it wiill be subtitled in AVID. Possibly also the title roller in the end.
A Quicktime should do it in this case, no?Sascha Engel
Terence Curren
May 2, 2009 at 2:28 pmYes, a QT will work fine for that.
Terence Curren
Burbank,Ca
