Activity Forums Adobe Premiere Pro Transfering Edits to Different Tracks (Help)
  • Transfering Edits to Different Tracks (Help)
    Posted by Joshua O’Malley on January 23, 2025 at 1:24 pm
    Hello, I have Audio Track A4 segmented into multiple parts with gaps in between. I’m trying to transfer those edits (segments & gaps) to Audio Track A1, A2, A3 as well as Video Track V1 so that I can align them all. After that, I intend to close the gaps. I currently have a full unsegmented (mostly) audio & video except for track Audio A4. How can I get around this without doing it manually through key shortcuts?
    Devrim Akteke
    replied 1 year, 7 months ago
    2 Members · 7 Replies
  • 7 Replies
  • Devrim Akteke
    January 23, 2025 at 1:34 pm
    Hi, I am not sure if I understood correctly. Are all these audio segments and video part of a multicam-style recording? So can you try to make a multicam by selecting these segments in the bin?
  • Joshua O’Malley
    January 28, 2025 at 9:23 am
    Hello, It’s not part of multicam. I have my video untouched and my audio cut up into bits. I want to cut the video the same way the audio is cut without having to go through each cut manually.
  • Devrim Akteke
    January 28, 2025 at 9:48 am
    You can select your video on the timeline, right-click, and choose Scene Edit Detection to cut it automatically on edit points.
  • Joshua O’Malley
    January 28, 2025 at 9:56 am
    I meant I have the audio cut up with gaps but the video isn’t. So here, for example, I want to cut A1, A2, A3 as well as V1 exactly like A5 without doing it manually. I also have the same issue in other projects for various reasons. A5 is not part of multi camera sequence.
  • Devrim Akteke
    January 28, 2025 at 11:22 am
    Well, it’s, not all automatic, but the fastest without any extra plugins or software. You can transcribe the text, filter all pauses, and delete them all in one go.
  • Joshua O’Malley
    January 28, 2025 at 1:07 pm
    Oh, unfortunately I can’t transcribe the text because the language is foregin & doesn’t apply to Premiere’s transcribe feature.
  • Devrim Akteke
    January 28, 2025 at 1:30 pm
    Just a guess here, even if it is a language Premiere Pro doesn’t understand; you need to identify audio gaps, so it should be able to identify the gaps no matter what language it is. You should give it a chance to try.
    If that does not work there are paid options, like gling.ai, timebolt.io, autocut etc.
