Activity Forums Panasonic Cameras Transfering a clip to a P2 Card
  • Transfering a clip to a P2 Card
    Posted by Pascal Greuter on February 10, 2010 at 2:02 pm
    Hello
    I’m looking for a workflow, to export motion graphics (i.e. a rendered composition from after effects) to a P2 card.
    The reason behind this is the following:
    I’m a graphic designer working for a tv station. To play back the opening sequence we have a P2 player. It would be very easy when I can copy all my graphics to the p2 card and they can play it back during the show.
    Any help would be appreciated!
    Regards, Pascal
    David Keslick replied 16 years, 6 months ago 4 Members · 4 Replies
  • Pascal Greuter
    February 10, 2010 at 4:24 pm
    I’ve found a solution.
    With Premiere CS4, I can export a timeline to a P2 card. Works very well!
    Cheers!
    Pascal
  • Jeremy Garchow
    February 10, 2010 at 6:22 pm
    MXF4mac is working on a P2 Export function that will export your FCP timeline to a P2 Card as well.
    https://mxf4mac.com/mxf-p2-export
    Jeremy
  • John Fishback
    February 10, 2010 at 8:19 pm
    While I’ve never tried doing it, I believe Raylight will write to P2 cards.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.1, Motion 4.0.1, Comp 3.5.1, DVDSP 4.2.2, Color 1.5.1)
  • David Keslick
    February 11, 2010 at 5:46 pm
    That is correct John. Raylight for Mac can convert your project to P2 structure or write it directly to a P2 card.
    Raylight Mac
    Dave Keslick
    DVFilm.com
