Activity › Forums › Event Videographers › transfering 8mm to dvd
  • transfering 8mm to dvd
    Posted by Zeynep on August 20, 2005 at 2:27 pm
    hi everyone,
    I like to transfer an 8 mm footage on to dvd and I like to do this cheaply..
    Does anyone give me advice?
    Thanks in advance.
    Doug Graham replied 21 years, 1 month ago 3 Members · 3 Replies
  • Doug Graham
    August 21, 2005 at 7:43 pm
    First of all, let’s clarify whether you are talking about 8mm videotape, or Super8 movie film.
    Regards,
    Doug Graham
  • Ralph Hajik
    August 22, 2005 at 6:20 am
    Hi All,
    That’s a good question. How do you take super 8 silent movie tape and convert or apply it to DVD. I’m using Vegas 6 and DVD3 if that helps. What tape decks or equipment do you need for that?
    Ralph
  • Doug Graham
    August 22, 2005 at 12:45 pm
    You gotta have a projector. If you can find one with variable speed, all the better. It’s nice if your camcorder has a “clear scan” shutter tweak setting, too.
    Both these items are used to reduce the strobing effect that you can get when 24 fps film is recorded by a 29.97 fps camera. (You might try 24 fps if your camcorder supports it; I haven’t heard from anyone who’s tried this, though).
    The simplest setup is to have the camcorder and projector side by side. Project the film image on a clean white sheet of paper (letter size is fine; you don’t need to blow the picture up big).
    A much better way involves the use of a telecine. Hollywood’s are VERY expensive, but there’s a fellow in Texas who makes a series of affordable ones: try https://www.moviestuff.tv/8mm_telecine.html
    Once the film’s been transferred to DV tape (or dumped straight to disk using your camera’s pass-through feature), you can edit, enhance, add music and narration, and author to DVD just like any other video.
    Regards,
    Doug Graham
