Activity Forums Maxon Cinema 4D Transfer weight from one joint to another
  • Transfer weight from one joint to another
    Posted by Alec Iselin on January 10, 2016 at 11:53 pm
    I’m trying to rig a face and so I have geometry with weight distributed across 3 or even 4 joints. Basically I want to take all of the weight off of one joint and transfer it to another without disturbing any other joints that also have weight on those vertices.
    c4d r15
    Not using Cactus Dan tools.
    Robert Krawczyk replied 4 years, 10 months ago 2 Members · 1 Reply
  • Robert Krawczyk
    November 19, 2021 at 1:53 pm
    I know this is old but here’s how you do it.
    Go in the Rigging layout or open Character > Manager > Weight Manager. In the Joints tab, select the source joint, then in the Commands tab, hit Copy, then Zero. Then select the destination joint and hit Replace or Merge.
