Transfer Position Problem
I have a bunch of strokes which I made by rightclick > “create shapes from Vector layers” on an AI file 1920/1080.
When I then copy the “path” from one of these strokes onto a “write on” effect on a different layer (also 1920/1080), the path is transferred but it is offset and all my attempts to fix it (except moving it by hand) failed.
Is someone familiar with this problem and knows how to deal with it?
EDIT: Here’s an important detail.
The offset looks like if the origin in the source layer is in the top left and in the destination layer in the center.
So for example if the stroke that I copy in originally in the center of the image it will be pasted to the lower right corner in the destination. I tried already to move the anchor point of the destination layer from center to 0,0. But it doesn’t seem to make any difference.EDIT2:
is there maybe any way to offset ALL keyframes (possibly with an expression?) in the “brush Position” Value? Brush Position is the value where I pasted the the path to.
