Activity › Forums › Adobe After Effects Expressions › transfer mode expressions?
Posted by Erin Shelby on November 7, 2005 at 10:14 pmare there expressions that can affect a layers transfer mode (to change from multiply to overlay for instance) or is this only in the realm of scripting?
Mylenium replied 20 years, 10 months ago 4 Members · 3 Replies -
Colin Braley
November 7, 2005 at 11:35 pmYou can’t keyframe (or add expressions to) a layers transfer mode. You can just split the layer and change the transfer mode at a specific point in time. If it is required that you set many keyframes of a layer’s blending mode I recommend checking out the Channel > Calculations effect.
~Colin
Chris Smith
November 8, 2005 at 1:46 amOr just duplicate the layer a handful of times, set them all to different transfer modes and use an expression to control which ones have the full opacity while the other’s have zero.
Chris Smith
https://www.sugarfilmproduction.com -
Mylenium
November 8, 2005 at 5:50 amLike the others said, you can’t manipulate that directly with expressions. However, some plugins have animatable transfer mode controls and you may wanna look into them. Try e.g. the Solid Composite effect.
Mylenium
[Pour Myl
