Activity Forums Panasonic Cameras Transfer HDV footage HVX200 Need Help ASAP please
  • Transfer HDV footage HVX200 Need Help ASAP please
    Posted by Gursimran Dhillon on August 3, 2008 at 5:34 pm
    Hello guys,
    I am in super need, we shot a cooking show on the HVX200 on the FS 100 and also HDV tapes, now i was able to transfer the the FS100 no problem to the Hard drive and start editing away, but we took a lot of shots with the DVX100 as a B camera. I came home and tried to import the tapes from my HVX200 and FCP Log and capture window comes up saying Looking for Time code, i tried to search this issue in Google and couldn’t find any helpful info at all. Can any one please tell me if i need to change the settings on my camera for import or what am i doing wrong here. The DVX100 shot the HDV tapes and the HVX200 was set up for FS100. I did not change any settings in the camera after taking the tapes from the DVX100 and trying to import it with the HVX200, Please let me know what i need to here.
    Thank you all.
    G.S. Dhillon
    Gursimran Dhillon replied 18 years, 1 month ago 3 Members · 5 Replies
  • Adam Smith
    August 3, 2008 at 7:12 pm
    You’re saying “HDV tapes” but I assume you mean DV recordings, right? Both cameras can only record/playback standard definition DV to tape, no HDV format, but DV tape stock may be being labeled as HDV these days.
    Just figured I should get that detail clarified before someone more knowledgeable than I steps in to help. How are you capturing the footage and controlling the camera?
    Video Photographer / Avid & Final Cut Editor
  • Gursimran Dhillon
    August 3, 2008 at 7:26 pm
    Thats right i’m using DV tapes, and when i go log and capture i can control the camera playback and view the footage only on the camera, and when i hit capture now, it says looking for timecode.
    G.S. Dhillon
  • Adam Smith
    August 3, 2008 at 7:48 pm
    Hmm.. yeah that’s a problem beyond my area of experience. =(
    Lots of knowledgeable people around here tho!
  • Michael Sacci
    August 3, 2008 at 11:34 pm
    What is your deck control set for in FCP L&C, it needs to be on Firewire. (this way you should also be able to control the camera.
    Also did you shoot the tapes on LP (90 minutes) vs SP (60 minutes)?
  • Gursimran Dhillon
    August 4, 2008 at 6:43 pm
    Thanks guys, i just imported all the footage using imovie it was a lot easier and then i transferred all the clips to fcp. Whatever works i guess right….i was trying to capture right from the camera to fcp, and that was the other best option i could think of.
    Thanks all for the input.
    G.S. Dhillon
