Activity Forums Adobe Premiere Pro transfer film to NLE for editing?
  • transfer film to NLE for editing?
    Posted by Twann Hudson on March 18, 2008 at 6:03 pm
    What is the process for getting film say 35 mm taken of a family vacation and getting it in to final cut or premiere for editing and then back again. I have read of people doing this, but I don’t have the foggiest idea of what is needed or even the cost of doing this. Can it be done at a home base business or do I need to take it some company and leave my first born as a down payment?
    Someone enlighten me!
    the real fun begins when the program loads
    Eric Jurgenson replied 18 years, 5 months ago 2 Members · 1 Reply
  • Eric Jurgenson
    March 19, 2008 at 1:50 pm
    I presume you are talking about snapshots.
    You can buy a scanner for under $100., but this is slow if you have a lot of images.
    I use a digital still camera set up on a tripod, and I place the snapshots one by one on a music stand to rephotograph the images. Don’t get hung up on framing at this point – leave some “bleed” around the edges (Try to get them level, though). This part goes quite quickly – much quicker than scanning. Then I transfer the digital stills to my computer and import them into Premiere. They typically have to be resized individually, which takes a bit of time. At this stage you can also set up pan/zoom moves using keyframes in the effect control window to add some zip to your “slide show”.
    Don’t use a super high resolution setting in your still camera – this will bog down Premiere. Use something around 1500 x 1000 pixels. This will give you enough resolution to allow zooming into your image without things getting soft.
