Activity › Forums › Boris FX › Transfer FCP Program Sequences to AE with Boris XML Transfer
  • Sean Trani
    December 3, 2009 at 5:04 pm
    Really great stuff. Installed the 14 day free trial today. Followed the instructions to a tee, got my trial serial key, loaded up After Effects, File > Import > Final Cut XML via Boris transfer….and Fail.
    “Your 14 day trial has expired.”
    Fantastic stuff.
  • Peter Mcauley
    December 3, 2009 at 7:48 pm
    Hi Sean,
    I’m surprised (as apparently you were) by this result. If you have not installed a trial of this filter on that system in the past then it should not have failed. We can fix that for you though. Please contact me directly – peterm@borisfx.com – and we’ll help.
    Cheers,
    Peter.
  • Robert Cameron
    December 3, 2009 at 9:49 pm
    Can anyone clarify the difference between what you get thru this Boris plugin vs from CyberDuck?
    -Rc
  • Matt Mullen
    December 4, 2009 at 3:08 pm
    Robert,
    I’m not familiar with CyberDuck (did you mean Automatic Duck?) but you can check out all the Boris XML documentation which will give you a better understanding (If you haven’t already of course).
    User Guide: https://www.borisfx.com/download_files/BorisXMLTransfer_HF.pdf
    Workflow Guide: https://www.borisfx.com/download_files/XMLHelpTutorial.pdf
  • Peter Mcauley
    December 4, 2009 at 3:17 pm
    Hi Robert,
    The main difference here is that because we (BorisFX) own the code for the BCC/FEC filter sets and the Boris XML Transfer code, we can better guarantee the transfer of these filters from FCP into AE.
    Cheers,
    Peter.
