Activity Forums Avid Media Composer Transcribing software that works with avid 8.3
  • Transcribing software that works with avid 8.3
    Posted by John Keating on April 9, 2015 at 1:47 am
    Does anyone know of transcription software that works with avid 8.? Perhaps there is a suggested workflow regarding this process. I’m at a loss.
    John
    John Pale replied 9 years, 10 months ago 6 Members · 6 Replies
  • Shane Ross
    April 9, 2015 at 2:59 am
    Well, the typical process is to watch Quicktime files with visible timecode and type what is being said in a word processor like Microsoft Word. Pausing the QT to help you catch up when falling behind. And adding timecodes of what is being said at regular intervals.
    And that pretty much is how it is done today. We export QT files with timecode and send them off to a transcription service that has people sitting down, listening and typing. There really is no software out there good enough to transcribe the QTs with speech recognition. Some have tried, but it gets comical when accents come into play, or people speak fast or stumble.
    Adobe had one that was about 50-60% accurate…which makes it useless, as needing to listen to the QTs and fix those errors makes using them in the first place not very practical.
    Shane
    Little Frog Post
  • Glenn Sakatch
    April 9, 2015 at 3:10 am
    The place we use, utilize court reporters, makes it go through pretty quickly.
    Glenn
  • John Keating
    April 9, 2015 at 9:49 am
    Shane,
    Thanks for responding Shane, this is a big help. Once you get the transcription back from the service what do you typically do with it?
  • Ricky Barrow
    April 9, 2015 at 12:25 pm
    Avid Script Sync with v. 7 and below but not v.8 – we keep v. 7 on one machine just for that process which can then be opened in v.8 for use.
    Ricky
  • Igor Jovcevski
    October 25, 2016 at 12:04 pm
    well https://edit8.com/transcribe_for_avid_media_composer/ would probably be one of the apps you’ll need. check great video explaining how it works.
  • John Pale
    October 31, 2016 at 12:49 pm
    For those interested, it was announced that the licensing issue with Nexeidia has been solved and Script Sync features will soon return in an upcoming version of Media Composer.
