Activity Forums Adobe Premiere Pro Transcribe audio in CS4 Greyed out
  • Transcribe audio in CS4 Greyed out
    Posted by William Sticht on January 19, 2009 at 1:58 pm
    I am trying to transcribe the audio of video clips that I have captured using the Matrox rtx100, but the transcribe button in the metadata window is greyed out. Does premiere not recognize certain codecs when it comes to transcribing? I have countless hours of video to work with so file conversion at this point is not an option. Any thoughts/suggestions are very much welcome and appreciated. This is the second time I have posted this but the first seems to have disappeared so I apologize if you have already read/answered.
    Fritz Sticht
    “If we couldn’t laugh, we would all go insane.” – Jimmy Buffett
    Yoann Guil replied 16 years, 4 months ago 7 Members · 6 Replies
  • Rick Sullivan
    February 28, 2009 at 8:57 pm
    William- I’m having the same issue. Di you find a solution?
    rick
    Rick Sullivan
    http://www.ricksullivanmedia.com
  • David Dobson
    June 3, 2009 at 9:41 pm
    Same problem – seems that transcription does not work on P2 .mfx files.
  • Aaron Will
    April 20, 2010 at 7:48 pm
    Same issues here, working with .mts files from my Canon HF10.
  • Jon Barrie
    April 20, 2010 at 11:45 pm
    I am not able to confirm this with experience but I have read some time ago that the folder structure of P2, mxf, (folder structure based) recording formats are locked and don’t allow for file writing = no ability to use the transcribe function.
    Switch the folder and file permissions and it should allow it.
    – JB
    Jon Barrie
    aJBprods
    http://www.jonbarrie.net
    http://www.suiteskills.com
  • Shahane Bekarian
    May 4, 2010 at 2:42 am
    Transcribe was greyed out for me too, for an .aif file.
    To transcribe I selected the file in the project window, went to the Clip menu>Audio options>Extract audio. Not sure what that does for a file that is already audio. This created a new file with a .mov suffix. With this new file I was able to choose Transcribe to text. Then the text will appear in the metadata tab, albeit not very accurate.
    Shahane
  • Yoann Guil
    May 6, 2010 at 5:59 pm
    Even fight no choice but audio transcription == text in English…I seek a solution…
