Activity Forums DaVinci Resolve Transcoding XDcam footage of premiere project for DaVinci Resolve import…
  • Transcoding XDcam footage of premiere project for DaVinci Resolve import…
    Posted by Pierre Paré-blais on December 7, 2011 at 3:24 pm
    I’ve tried posting this message in the Premiere forum, unfortunatly with no response, so I though maybe I’d have more luck in the davinci forum.
    Here’s goes:
    I’ve recently finished editing a short videoclip in premiere. it is a simple two camera 5min edit of a section of a live concert event, one clip is from a DSLR the other a sony EX3.
    Now that I’ve completed the edit I want to take my sequence to Resolve to finish, but resolve doesn’t support XDCAM file (native or quicktime codec I believe), so I have to transcode the one XDCAM clip (which is a long clip chopped up and used several times in the edit) to prores 422 or 444. Now I tried to manually export the clip in premiere (file>export>media) to a proress quicktime with all the proper frame rate/size/etc. to match the clip, but the resulting clip has lost the timecode of the original, and so when I replace the clip in my edit by this converted clip, it no longer matches and my edit goes to hell!
    Because the clip is a long take (1h), it’s been broken up by the camera into multiple mp4 clips with smi files (which premiere reads as one single clip), so the watch folder method doesn’t work because it results in it transcoding each sub clip into its own quicktime file and still no timecode.
    So this is where I’m stuck… because it’s a small edit and for the web, I can always just grade inside premiere this one time… but Resolve has become my new platform of choice for grading (specially since the death of Color and the new 8.1.1 update to the free version), and so finding a solution to this is essential to me, because the XDCAM format is one I use frequently…
    thanks for any help.
    for reference I’m on a Mac Pro dual quad-core, 8gb ram, OSX Lion 10.7.2, CS5.5, Resolve lite 8.1.1
    Pierre P. Blais
    Multimedia performance and VFX artist
    Pierre P. Blais Productions
    Perception Films
    https://www.vimeo.com/user1771129
    John Sellars replied 14 years, 6 months ago 4 Members · 7 Replies
  • 7 Replies
  • Richard Cooper
    December 7, 2011 at 11:40 pm
    I am just coming over from COLOR my self and starting to learn Resolve so don’t take this as gospel, but can you export a single master file of your Premiere timeline, then export an EDL of the timeline, put the master video in our Resolve media pool and import the EDL, and grade that? I actually read about this workflow and experimented with it (but only once) and it seemed to work quite nicely. All the cuts and dissolves showed up on the Resolve timeline perfectly.
    Let me know how this works.
    Good Luck!
    Richard Cooper
    FrostLine Productions, LLC
    Anchorage, Alaska
    http://www.frostlineproductions.com
  • Ola Haldor voll
    December 7, 2011 at 11:46 pm
    XDCAM in .mov container is supported. I’ve had projects with that codec since before xmas last year. Note though; it’s kind of heavy and sluggish to work with – but it works.
  • Pierre Paré-blais
    December 8, 2011 at 4:24 am
    that’s good to know. Thanks!
    Pierre P. Blais
    Perception Films
  • Pierre Paré-blais
    December 8, 2011 at 4:36 am
    That’s not crazy, I’ll give it a try, thanks.
    I think I read something similar on Walter Biscardi’s forum, but he didn’t use an edl I think, just Resolve’s built-in edit detection tool. Although I fail to understand how dissolves would show up properly, wouldn’t those get baked in when you export the master file?
    Pierre P. Blais
    Perception Films
  • John Sellars
    February 8, 2012 at 3:05 am
    I am trying to import an AAF from Symphony 6.0 and only a few of the hundreds of clips are showing up. It was shot on XDCAM (EX3) but the files are mp4. Is that the problem? Quicktime 7 doesn’t recognize them but VLC does.
  • Pierre Paré-blais
    February 8, 2012 at 3:26 am
    I’ve done the Avid to Resolve workflow a couple of times now, based on what your saying I am assuming your files are brought into Symphony with Avid AMA system right? in other words, avid is looking at the original mp4 files to avoid having to transcode. However, in order for the AAF to work properly in resolve, you need to either transcode the media or consolidate the project to DNxHD, ideally the 10-bit flavor that corresponds to your project (220 for 30fps, and 175 for 24fps projects). Resolves does not support native XDcam footage, it only supports the quicktime rapper (which you get when transcoding in Final Cut pro). Once you’ve gone through the transcoding process, you make the aaf with the “reference media files” option and not “copy media”, you then bring in the AAF into Resolve and point resolve to the media drive that contains the mxf media for your project. Everything should link up just fine, so long as there are no timecode conflict. I’ve done quite a few time but coming from Media Composer 6 and it always works fine for me, although at first I had to fiddle around quite a few time to finally get the right kind of AAF for resolve.
    Pierre P. Blais
    Perception Films
  • John Sellars
    February 19, 2012 at 1:14 am
    That was it, thanks. Still having timecode errors on some clips (yes, they do have embedded timecode), but at least it’s working…
