Activity Forums Apple Final Cut Pro Legacy Transcoding vs Capturing
  • Transcoding vs Capturing
    Posted by Thomas Morter-laing on September 13, 2011 at 10:59 am
    Sorry, pretty basic question, just worth checking-
    If you capture as HDV and then transcode to prores 422 using (for example) MPEG Streamclip, will it yield the same quality as when you capture using HDV- Prores 422 in FCP7?
    (PS, pls dont start telling me about prores not adding quality etc, Im talking more about transcoding generational degradation, not about why I should transcode to prores- just need to know if by using the HDV-prores capture setting, its essentially just transcoding on capture, rather than afterwards:).
    Tom Morter-Laing
    Freelance Editor,
    Certified Apple Product Proffessional, 2010
    http://www.depictproductions.co.uk
    Sony Z5, with Rode NTG2.
    iMac 27″ intel i7 2.93GHz, 12GB RAM, ATI HD5750 [1GB GDDR5], 2TB Int. SATA with 2TB External HDD; (FW800), with Elgato Turbo H264HD.
    Jeff Greenberg replied 15 years ago 3 Members · 2 Replies
  • Rafael Amador
    September 13, 2011 at 1:34 pm
    [Thomas Morter-Laing] “If you capture as HDV and then transcode to prores 422 using (for example) MPEG Streamclip, will it yield the same quality as when you capture using HDV- Prores 422 in FCP7?”
    When capturing in FC, the transcoding is done in RT while when you convert something on your computer things normally takes longer. I understand that in the second case the process can be done with more precision.
    Capturing trough something like an AJA would be a different matter.
    rafael
    http://www.nagavideo.com
  • Jeff Greenberg
    September 13, 2011 at 4:43 pm
    It will probably be the same quality, or the difference will be negligible.
    Best,
    Jeff G
    Apple Master Trainer | Avid Cert. Instructor DS/MC | Adobe Cert. Instructor
    You should follow me (filmgeek) on twitter. I promise to be nice.
    New- my book (with Richard Harrington and Robbie Carman)- An Editor’s Guide to Adobe Premiere Pro
    Compressor Essentials from Lynda.com
    (older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
    Contact me through my Website
