Activity › Forums › Adobe Premiere Pro › transcoding to Proxy media
  • transcoding to Proxy media
    Posted by Bryce Douglass on February 13, 2016 at 3:45 am
    Hello,
    I have a really slow macbook that I might edit video on occasionally. I want to transcode my footage to a Proxy media. Do I have to use Pro Res Proxy if I have HQ clips as Pro Res or does anything work for Proxy Files?
    Bryce
    Lisa Bradley replied 10 years, 7 months ago 5 Members · 7 Replies
  • 7 Replies
  • Tero Ahlfors
    February 13, 2016 at 6:50 am
    [Bryce Moose] ” Do I have to use Pro Res Proxy”
    Nope
    [Bryce Moose] “or does anything work for Proxy Files?”
    Yes. Pick a proxy that your computer can run.
  • Bryce Douglass
    February 13, 2016 at 7:28 pm
    How do I make a proxy file though?
    Bryce
  • Alex Udell
    February 15, 2016 at 4:15 pm
  • Bryce Douglass
    February 22, 2016 at 9:02 pm
    I don’t think I’m explaining myself correctly. What I mean is what settings do I select in Media Encoder to make a Proxy file?
    Bryce
  • Lisa Bradley
    February 23, 2016 at 7:56 pm
    ProRes Proxy.
    Lisa Bradley
    Editor/Videographer
  • Shane Ross
    February 23, 2016 at 9:11 pm
    Question. When you make that ProRes Proxy media with Media Encoder…does it retain all the metadata so that you an then relink to the masters when you are done cutting?
    Shane
    Little Frog Post
  • Lisa Bradley
    February 23, 2016 at 10:06 pm
    As long as file names remain the same and you don’t accidentally overwrite your camera raw files you will be able to link. Eek!
    PR Proxy is just a codec; that being said, if you go into media encoder, there is a box that should say “match source” so if you are editing with 4k, your proxies will be 4k so that when you create your graded string out, any movement/rescaling will easily translate over when you paste attributes. Does that make sense? Hopefully that answers your question.
    Lisa Bradley
    Editor/Videographer
