Activity Forums Adobe Encore DVD Transcoding setting question
  • Transcoding setting question
    Posted by Julio Crespo on October 7, 2006 at 6:57 pm
    HI
    I Have a 2 hours NTSC DV video with one simple very Menu and I like to fit it into a DVD-R 4.7GB single layer, What the best setting to do this? does this media is the best?.
    thanks in advance
    Neil Wilkes replied 19 years, 11 months ago 2 Members · 1 Reply
  • Neil Wilkes
    October 10, 2006 at 3:02 pm
    Use Encore’s “Automatic” setting.
    2 hours is pushing it for a single layer disc in terms of quality, and will result in a bitrate of 4.82 average with VBR encoding.
    (Encore will automatically use VBR encoding at anything under 6Mb/sec as a rough guide)
    Whether or not this is acceptable will depend on your source footage.
    If there is a lot of rapid motion & fast stuff, or heavily detailed scenes, it might not be sufficient.
    To test, try taking the busiest clip you can & transcode it using the following settings:
    VBR 2-Pass
    Peak Bitrate = 9.41Mb/sec
    Average (Target) bitrate = 4.82Mb/sec
    Write to an RW disc, and see what it looks like…..
