Activity Forums Avid Media Composer Transcoding screws up .mov audio
  • Transcoding screws up .mov audio
    Posted by Ryan Tiedgen on January 11, 2011 at 9:06 pm
    Hey ya’ll,
    So I’m doing some casting editing, and all the footage I’m sent are .mov files captured in Quicktime. They are large so I went to the AMA / transcode workflow I’ve been reading so much about.
    But when I do this, the audio on the resulting media slides WAY out of synch, more and more as the clip goes on.
    What’s the deal with this? Is there a fix or is this function really just for DNxHD stuff?
    Indeed this is not a life or death matter, whenever you get a chance
    THANKS
    Power Mac G5 2×2.66 GHz Dual-Core Intel Xeon
    Running Avid MC5 on Snow Leopard
    Jeff Greenberg replied 15 years, 8 months ago 3 Members · 7 Replies
  • 7 Replies
  • Shane Ross
    January 11, 2011 at 9:59 pm
    [Ryan Tiedgen] “all the footage I’m sent are .mov files captured in Quicktime.”
    Captured HOW? And to what codec? what dimensions?
    Shane
  • Ryan Tiedgen
    January 11, 2011 at 10:58 pm
    I’m unsure about the camera, but the original file is a Quicktime movie (720×480, H.264 and AAC codecs, Color Profile: SD (6-1-6), 2 audio channels)
  • Shane Ross
    January 11, 2011 at 11:03 pm
    DNxHD is for HD formats. That’s an SD format. Gotta transcode to an SD codec.
    Shane
  • Ryan Tiedgen
    January 12, 2011 at 12:11 am
    I’m not doing anything with DNxHD now though, I was just referencing it, sorry if that was confusing.
    It’s a 16×9 project, 30i NTSC
    When I link to AMA files, would transcoding to SD be in the Target Video Resolution drop down then? 1:1? I have been choosing DV 411 MXF, thinking that was for sure what I wanted.
  • Jeff Greenberg
    January 12, 2011 at 7:12 pm
    When you transcode you could go to any video format you like – I’d suggest at least DV50 over DV25 411 – and uncompressed (1:1) would create huge files, but wouldn’t add any additional compression.
    Since you’re starting with highly compressed SD files (h264) you might not want to add any further compression.
    Best,
    Jeff G
  • Ryan Tiedgen
    January 13, 2011 at 1:22 am
    Ok, I can try to do that at some point, but the fact remains that when I transcode media that I have linked through AMA, the resulting clips have severely drifting audio unlike the in-synch originals.
    Is there anyone else having this problem?
  • Jeff Greenberg
    January 13, 2011 at 2:58 am
    I’m curious – is it a frame rate match? For example are you transcoding 24p material in a 30i timeline?
    Best,
    Jeff G
