Activity › Forums › Business & Career Building › Transcoding rates
Transcoding rates
Posted by Bruno Silva on June 26, 2011 at 7:13 pmI recently started freelancing as an Editor and a web designed has requested that I transcode a WMV file to an FLV file for a client’s website. What do you guys usually charge, or suggest I charge, for something like this?
ThanksScott Sheriff replied 15 years, 2 months ago 5 Members · 7 Replies -
Rob Grauert
June 27, 2011 at 12:52 pm[Mike Smith] “Why would that be oustide of your normal time rate …?”
Well, I’ve asked myself the same question Bruno is asking, because you are just sitting there letting the computer do the work. The client should pay for your knowledge and expertise, but perhaps on a per-file basis rather than your usual hourly rate?
Don’t post houses do this with tapes? It’s just a flat rate to transfer something to tape? Why not the same for transcoding. A flat price per file. Or a flat price per XX minutes of video that has to be transcoded.
Rob Grauert, Jr.
http://www.robgrauert.com
command-r.tumblr.com -
Bruno Silva
June 27, 2011 at 4:44 pmI didnt want to charge an hourly rate. I did some research and post houses charges around $25 so I’ll work with that number.
Rob Grauert
June 27, 2011 at 5:21 pmThat sounds good. I think it’s worth considering the length of the videos that need transcode, too. For instance, an 27 minute HDCam tape is $35. Maybe I would charge $35 for every file that a client wanted transcoded, and/or if the file is longer than 27 minute I’d charge $35 for every 27-minutes of video they want transcoded. Or just flat out $35 for every 27 minutes of video they want transcoded.
I’m sure you get the picture.
Rob Grauert, Jr.
Mick Haensler
June 29, 2011 at 3:48 pmI charge $25 per half hour. I also have my software on my laptop so it doesn’t tie up my workstation.
Mick Haensler
Higher Ground Media -
Scott Sheriff
July 1, 2011 at 12:27 am[bruno silva] “I recently started freelancing as an Editor and a web designed has requested that I transcode a WMV file to an FLV file for a client’s website. What do you guys usually charge, or suggest I charge, for something like this?
Thanks”It depends on how long it is.
If it is short and part of an hourly edit session, I do it at the editing rate.
Something that is long, or stand alone type work that I can let run while I’m doing something else (end of day/overnight) I charge less than the edit rate.
Actual rate depends on your geographic area.Scott Sheriff
Director
https://www.sstdigitalmedia.comI have a system, it has stuff in it, and stuff hooked to it. I have a camera, it can record stuff. I read the manuals, and know how to use this stuff and lots of other stuff too.
You should be suitably impressed…“If you think it’s expensive to hire a professional to do the job, wait until you hire an amateur.” —Red Adair
