Activity Forums Avid Media Composer Transcoding Question
  • Transcoding Question
    Posted by Carla Cardello on February 22, 2011 at 4:34 pm
    I apologize in advance for my lack of knowledge when it comes to the really technical stuff. I’m trying my best to learn though!
    Ok so I received MXF files. However, when I go to relink them, it says wrong format. After some research, I discovered Media Xpress does not support 2:1, which is what I’m trying to relink.
    How can I transcode them? I know one option is to upgrade to Media Composer, but I’m not sure about fitting this into our budget (I work for a training department for machinery, so our budget is dedicated to more than just video needs). However, if I can make a strong case, I may be able to convince my boss.
    I work on a PC. Besides Xpress, I have Sorenson Squeeze, Pro Tools, Quicktime (regular not pro), and Adobe Production CS5 Suite, which includes Media Encoder.
    Michael Hancock replied 15 years, 7 months ago 3 Members · 5 Replies
  • Michael Phillips
    February 22, 2011 at 4:55 pm
    Can whomever sent you the files transcode to a format that is supported?
    Michael
    Michael Phillips
  • Carla Cardello
    February 22, 2011 at 6:01 pm
    Yes, but because they are in WI and I am in PA, it will take some time. I was just wondering if there was anything I could do now instead of waiting for mail.
  • Michael Hancock
    February 22, 2011 at 6:26 pm
    Download the trial of Media Composer 5. Install it on another machine, load the media and Avid project you’ve received, transcode the footage to a format your Avid can read, transfer the transcoded footage back over.
    Explain to management that, for probably less than $1,000 in upgrade costs, you could just upgrade to MC5 and avoid the wasted time transcoding. Might help get you the upgrade.
    Michael
    Michael Hancock
    http://www.oswaldcommunications.com
  • Carla Cardello
    February 22, 2011 at 8:38 pm
    Good idea! Does it have to be a different machine? I’m guessing because the trial will fight with my current software?
    I don’t find myself working with mxf files that often. In fact, this is my first time, hence why I didn’t know about Xpress not reading 2:1. This was a one-time-deal because it is b-roll footage to use for future videos. Usually I’m on my own in getting shots, and I was surprised they even gave it to me when I asked. If I do find myself in this situation often (which if they said yes once…), then I could argue about saving time.
    Thank you.
  • Michael Hancock
    February 22, 2011 at 9:52 pm
    [Carla Cardello] “Does it have to be a different machine? I’m guessing because the trial will fight with my current software?”
    Exactly. You’re just inviting trouble if you install a newer version over the top of the old one.
    [Carla Cardello] “I don’t find myself working with mxf files that often. In fact, this is my first time, hence why I didn’t know about Xpress not reading 2:1”
    I don’t believe Xpress ever read 2:1. It did DV50, DV25, some offline resolutions and 1:1 only. Hence your troubles.
    [Carla Cardello] “If I do find myself in this situation often (which if they said yes once…), then I could argue about saving time. “
    Play with the MC 5 trial for a bit. There are so many improvements over Xpress Pro you’ll save huge amounts of time and have much, much greater capabilities. I’d push hard for the upgrade – maybe wait until MC 5.5 drops in March. It’s definitely worth it.
    Michael Hancock
