Activity › Forums › Apple Final Cut Pro Legacy › Transcoding Proress 4444 to small file
  • Transcoding Proress 4444 to small file
    Posted by Mike Noneofyourbusiness on March 14, 2013 at 6:41 am
    I am editing in FCP7 with a prores 4444 timeline. I have the visual done and I wanted to export a small sized file that can be sent to the sound designer and the music composer. I normally work with 422 (HQ) and I just make a h.264 file and set the slider to just below high and use acc sound and the files are small but still look good and I use these settings to post stuff on vimeo as well and they look absolutely fine…but with this project they come out looking like old youtube videos. I have done it through file>export>quicktime conversion and i have tried using compressor.
    Could anyone suggested a how to export a smaller files that can easily be uploaded and download but still look good?
    Thanks.
    Shane Ross replied 13 years, 6 months ago 3 Members · 3 Replies
  • Spencer Averick
    March 14, 2013 at 6:53 am
    Export a full res Quicktime Movie first, then bring it into Compressor and add the H.264 Webcast setting to it, then adjust these settings:
    -Geometry>Frame Size 960×540
    -Encoder>Video Settings>Frame Rate set to “current”
    -Encoder>Video Settings>Restrict Data Rate to 2000 or even 1000 is fine if the source material is good.
  • Mike Noneofyourbusiness
    March 14, 2013 at 7:26 am
    Thank you so much for replying, it is very much appreciated, I will try this asap.
    Cheers.
  • Shane Ross
    March 14, 2013 at 6:59 pm
    I just have to say…I like your last name.
    Shane
    Little Frog Post
