Activity Forums Apple Final Cut Pro Legacy Transcoding PAL Mini DV to Apple ProRes 422 23.98
  • Transcoding PAL Mini DV to Apple ProRes 422 23.98
    Posted by Andy Lawless on March 17, 2011 at 11:55 pm
    Hi There;
    I’m editing a project in FCP that’s using both PAL Mini DV footage and Canon 7D footage. I’ve transcoded the Canon footage to Apple ProRes 422 1920×1080 @ 23.98 progressive. I’m looking for the best Compressor settings to transcode the PAL Mini DV footage to match the Canon footage if possible. I realize I’d be up-ressing from an interlaced source 720×576 @ 25fps, and wonder if it’s even possible to get a good ProRes 1920×1080 clip at 23.98 progressive? If anyone has any advice to share, I’d greatly appreciate it.
    Thanks;
    Andy
    Andy Lawless replied 15 years, 6 months ago 2 Members · 2 Replies
  • Michael Gissing
    March 18, 2011 at 12:14 am
    DV is not a good place to start. Are you slowing down from 25 to 23.98 in Compressor or must it be real time? If real time, then I would seriously consider a hardware uprez and frame rate conversion – Teranex etc
  • Andy Lawless
    March 18, 2011 at 2:12 am
    Yeah, unfortunately the DV is the master for the PAL stuff. You’re probably right about hardware up-res, but resources are limited to capturing off of a PAL DV camcorder via firewire.
