Activity Forums Avid Media Composer Transcoding P2 Footage in Avid
  • Transcoding P2 Footage in Avid
    Posted by Andrew Stewart on September 16, 2014 at 9:36 am
    Hi folks
    I have a strange one here that’s puzzling a few of the editors I work with. Working on a broadcast doc which was shot on P2 at AVC-I100 1080i/25pn. Worked offline at DNX36 but now at the grading stage, usual practice here is to duplicate sequence, make media offline then relink to original camera rushes and transcode to DNX-HD185. However after the transcode there is a noticeable deterioration in the images, with banding visible in shaded areas. Yet when I apply the exact same grade to the AMA Linked flies they’re perfectly clean.
    I’ve only recently upgraded from Symphony 6 and Im wondering if this is a Version 8 thing?? Thoughts anyone?
    I love tape, I really do.
    Andrew Stewart replied 11 years, 12 months ago 3 Members · 4 Replies
  • Michael Phillips
    September 16, 2014 at 12:40 pm
    As a test, what does it look like if you render the color corrected AMA linked clips to the same target resolution?
    Michael
  • Andrew Stewart
    September 16, 2014 at 12:52 pm
    Hi Michael
    That’s the strange thing. I did a test last night, put the same shot on the sequence twice, one transcoded and one AMA, applied the grade to both and then did a video mixdown of the sequence at 185. The AMA linked clip was still fine.
    Andrew
  • Robert Pitman
    September 17, 2014 at 2:39 am
    Hello Andrew,
    Try DNxHD 185X so your transcode is 10bit like the AVC-Intra AMA footage…
    I’m going by https://en.wikipedia.org/wiki/AVC-Intra as I’ve not used P2 AVC-Intra files before.
    Also look at “Media Creation” “Render” “Effects Processing” is not set to 8-bit?
    I hope this helps?
    Regards,
    Robert
  • Andrew Stewart
    September 18, 2014 at 10:46 pm
    Hi Robert
    Think you were right on the money there. It appears to have been the settings under ‘Media Creation’ etc.
    Thanks for that! Greatly appreciated.
    Andrew
