Activity Forums Apple Final Cut Pro Legacy transcoding in compressor
  • transcoding in compressor
    Posted by Jose Arce on June 13, 2009 at 12:41 am
    Hi, I make a Animation in after effects at 32bpc I export in quicktime animation, when I decide make the dvd I need to know which is the best way to export into a DVD in compressor or other program, I don want to loose quality, Some pictures lost quality in the black areas. Thank you
    Rafael Amador replied 17 years, 2 months ago 2 Members · 3 Replies
  • Rafael Amador
    June 13, 2009 at 3:08 am
    Hi Jose,
    Are you exporting from AE with Alpha Channel?
    If not, you better export from AE with a 10b codec (Uncompress/Prores).
    If you are rendering in 32b and exporting in 8b, there is a lot lost in the middle.
    rafael
    http://www.nagavideo.com
  • Jose Arce
    June 14, 2009 at 3:10 am
    Yes I’m working in 32 bpc, and export in Animation.
    Thanks, I going to do some testing.
  • Rafael Amador
    June 14, 2009 at 1:34 pm
    I use Sheer, 8/10b Unc and with Alpha.
    You can use also the AVID codecs. They are are free and all support Alpha.
    rafael
