Activity › Forums › Apple Final Cut Pro Legacy › Transcoding footage for FCP
Posted by Jesse Austin on February 9, 2012 at 11:49 pmHi all,
question I need to trans-code some footage that was shot on a Sanyo camera, no idea what one. The footage is H264 1920×1080. What would be a good codec for the edit.
The final outcome will be YouTube and a website.Thanks
Jess
Jesse Austin replied 14 years, 7 months ago 2 Members · 5 Replies -
Shane Ross
February 10, 2012 at 12:49 amProRes 422 or ProRes LT. Use MPEG STREAMCLIP for this…or Compressor.
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Jesse Austin
February 10, 2012 at 4:19 amThanks for the help; I was guessing someone out there would suggest this codec.
Thanks for the info…
Jess
Jesse Austin
February 10, 2012 at 5:00 pmHey Shane,
Question, I came across the Apple Intermediate Codec. Do you have any thoughts on this?I tried a test with a smaller 85 mb H264 file, once trans-coded it was about 150 mb’s or so and still looked great.
I tried a test with the same file, trans-coded to pro res and it was huge compared to its original.Thanks again for the help.
Jess
Shane Ross
February 10, 2012 at 6:31 pmAIC is lossy. It isn’t as high quality as ProRes. If you compared both on an external Broadcast quality monitor, you’d see it right away. Plus, AIC doesn’t always bring over the camera timecode. It was a stop-gap format to enable early versions of FCP to work with HDV.
Shane
Little Frog Post
