Activity Forums Apple Final Cut Pro Legacy Transcoding first or rendering file on sequence, same quality?
  • Transcoding first or rendering file on sequence, same quality?
    Posted by Dave Gage on August 7, 2010 at 1:19 am
    Please disregard the work flow aspects of this, but…
    Will adding a file type that is not pre-transcoded to ProRes 422 to a ProRes 422 sequence, which of course will need to be rendered to conform, end up being the same quality as if I had transcoded the file previously?
    In some cases, it’s easier for me to drag a bunch of files into the Browser, preview them, add In and Out points to a select few and then render on the timeline. I haven’t noticed any quality issues or problems, I was just wondering if I’m missing something.
    Dave
    Dave Gage replied 16 years, 1 month ago 3 Members · 4 Replies
  • Jerry Hofmann
    August 8, 2010 at 1:26 pm
    You’re not missing anything… it’s the same quality either way as far as I know.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
  • Dave Gage
    August 8, 2010 at 5:53 pm
    Jerry,
    I appreciate your reply. This will simplify my workflow quite a bit. If a move an originally non-ProRes clip in the sequence, it does not need to be re-rendered (only the transitions, which is fine).
    If I take the the same clip and copy it over to a new sequence within the same project, I do need to re-render it, but I’m fine with this as I don’t see this coming up much for me (no outside clients, just my work and family projects).
    Thanks again,
    Dave
  • John Fishback
    August 8, 2010 at 8:14 pm
    I think if a clip needs to be retimed and/or rescaled, you’ll have better results using Compressor which does a much better job at those tasks than FCP. Turning on Frame Controls and upping the quality settings to best produces very good results, although, it can take a while. You can test this easily by dropping a short non-ProRes clip into a ProRes sequence and rendering it. Then, convert the same file in Compressor to ProRes. Bring that file into the same sequence and play to compare. Be sure to use a broadcast monitor.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
  • Dave Gage
    August 9, 2010 at 3:42 am
    John,
    Thank you for your thoughts. I’m a big fan of the Frame Controls in Compressor and have had excellent results with them on Best and even Better settings.
    I like your thought on the quick comparison, I will give that a try.
    Dave
