Activity Forums Adobe Premiere Pro Transcoding error (2.0)
  • Transcoding error (2.0)
    Posted by Robert Shank on May 13, 2009 at 11:14 am
    Okay, I am using Adobe Premier Pro 2.0, only because of the DVD menu options it has to offer. I burned one project just fine, but on my other similar project, I got what is called a “transcoding error” message three separate times. I tried to burn my project straight onto a DVD and than I tried to burn it as an ISO. All three times, I got the same message at the same percentage time of completion.
    I have read some of the other threads about this topic and have tried what has been suggested, but to no avail. This is the first time I have received this message and only with this project file. All my files are linked correctly and I have no dead heads!
    I have enclosed two screen capture shots. The first one is the settings, right before it is burned to DVD. The second one is of the transcoding error message (I have added a red arrow, so you can see where it is).
    Robert Shank replied 17 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
