Activity Forums Adobe Premiere Pro Transcoding error
  • Transcoding error
    Posted by Martin on August 22, 2007 at 6:37 am
    Got 30 min’s of Dv footage on the time line. 22 audio tracks. 11 video tracks. Got 25GB on C/ Got 140GB on G/. Got G/ has my scrach disk. but have tried C/ with same result.
    Problem, Export to DVD or Folder. 40% through I have a Transcoding error?…..P.P stops doing it’s things at 40%. When I cancel I get message ” P.P Running low on system memory. I have Dual xeon 3.2 with 8 Gb Ram nvida 3500 fx video card. Can any one shed some light here please?…..
    Martin
    Martin replied 19 years, 1 month ago 2 Members · 3 Replies
  • Harm Millaard
    August 22, 2007 at 8:36 am
    Not a solution, but a workaround. Export to movie, AVI format, add to project, add a new sequence and put the exported AVI in the time line. Export that sequence to DVD. Does that work?
    If it works, then possibly the number of tracks in use may be the culprit. If it does not work, look closely at the time line around 40% to see if there is possibly a blank piece in the original time line.
  • Martin
    August 22, 2007 at 7:06 pm
    Did that’export to movie. Unkown error after about 8 hours and 80% compleated….Looking now for the possible blank piece in time line….
  • Martin
    August 24, 2007 at 12:48 pm
    Harm nothing worked. You was’nt wrong about going round the back door. I needed to act like a ninja PP. was falling to bits at every opertunity. I nealy lost 3 month work. The end for Adobe for me!…..Thanks for the tips anyway.I’m Glad it’s all over…..just!
