Activity › Forums › Apple Final Cut Pro Legacy › Transcoding Canon 7D 60fps footage into 24fps?
Posted by Sean Kapleton on March 2, 2010 at 2:58 pmGood Morning,
What would be the best way to do this transcode? I know to use Compressor to batch all of my footage into ProRes HQ for FCP editing but I am just curious as to what method (i.e. cinema tools) people recommend for this process.
thanks in advance
sean
Arnie Schlissel replied 16 years, 7 months ago 4 Members · 5 Replies -
Trevor Ward
March 2, 2010 at 3:21 pmCinema tools, batch conform. Easy as pie. Well, maybe not quite that easy. But easy and quick.
Just to be clear, if you’ve already transcoded the 60p material into ProRes, then you won’t need to transcode again. Transcode refers to the changing of codecs and/or resolution. If you’re just changing frame rate, then conform is the word you’re looking at.
-trevor ward
Red Eye Film Co.
http://www.redeyefilmco.com
orlando, fl -
Peter Wiggins
March 2, 2010 at 5:51 pmMarch 17th will see the release of the Canon plugin for Log & Transfer, so that will be the easiest way to do it from then.
Peter
Trevor Ward
March 2, 2010 at 5:54 pmExcept for the fact that Log and Transfer will not let you conform your media. Cinema tools is the best and easiest way to do that.
-trevor ward
Red Eye Film Co.
orlando, fl -
Arnie Schlissel
March 3, 2010 at 2:57 amDo you want to slow the footage down or do you want it to play at the same speed? If you want to slow it down you can use Cinema Tools after you transcode in Compressor.
If you want it to play at the same speed, look down 7 threads below this one to see what I advised Wiremu Harpuka about using Compressor to transcode from 30P to 25P.
Arnie
Post production is not an afterthought!
https://www.arniepix.com/
