Activity Forums Adobe Media Encoder Transcoding C300 .mxf files to ProRes using AME
  • Transcoding C300 .mxf files to ProRes using AME
    Posted by Sean Meehan on July 3, 2012 at 11:14 pm
    Hi all,
    Although Premiere can work with C300 .mxf files natively, I’d like to transcode everything to ProRes anyway. I thought I had copied the entire card structure over, but when I attempt to drag a file (or files) into AME to transcode, it tells me that it “cannot read from the source.” Is this indicating that I didn’t copy over the entire card structure, and therefore it won’t let me transcode? Does anybody have a workaround to convert these .mxf files to ProRes?
    Sean Meehan
    Sean Meehan replied 14 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
