Activity › Forums › Avid Media Composer › Transcoding a subclip
  • Transcoding a subclip
    Posted by Sean Lennon on April 11, 2019 at 7:09 pm
    Hi, when transcoding a subclip created at the link to media stage, is it transcoded like any other master clip in a bin? If I select the full clip in its bin and the subclip of that clip in its bin, will they both be transcoded in the same way? Hope this is making sense.
    Any help appreciated
    S
    Glenn Sakatch replied 7 years, 5 months ago 3 Members · 8 Replies
  • 8 Replies
  • Pat Horridge
    April 12, 2019 at 5:59 am
    It would but its not very efficient.
    You’d end up with media for the subclip and media for the full clip.
    The more effecient method is to transcode the full clip and then relink the subclip to that new media.
    Pat Horridge
    Broadcast & Post Consultant, Trainer, Avid Certified Instructor
    Free online Tutorials at VET digital media academy online https://vimeo.com/channels/752951
    pat@vet.co.uk
  • Sean Lennon
    April 13, 2019 at 2:59 pm
    Thank you!
  • Sean Lennon
    April 13, 2019 at 5:53 pm
    Hi, How do I know when the subclips are relinked, I’ve transcoded the clips that i’d made subclips from, I’ve relinked the subclips, but i’m not sure if i’m choosing the right relink options.
    Thanks again.
    s
  • Pat Horridge
    April 13, 2019 at 5:58 pm
    There is a bin column that shows the codec of the clip. You can also right click and select reveal file to see the media file.
    Pat Horridge
    pat@vet.co.uk
  • Sean Lennon
    April 13, 2019 at 6:07 pm
    It says I can’t reveal file for subclips, the bin column is saying its still AVC Long GOP, would this be because I still have the original, not transcoded files in another bin aswell?
  • Pat Horridge
    April 13, 2019 at 6:10 pm
    Then they aren’t re linked yet.
    Copy the sub clips and the transcode master clips to a new bin. Ose every other bin.
    Select the subclip and then relink and chose the section option relink to selected open bins.
    Pat Horridge
    pat@vet.co.uk
  • Sean Lennon
    April 13, 2019 at 6:38 pm
    When you say, copy the subclips do you mean consolidate in Avid speak?
  • Glenn Sakatch
    April 14, 2019 at 3:29 pm
    Another way would be to cut your subclps on a timeline, and then (hamburger menu) show clip colors in the timeline. Turn on purple for linked clips. Any clips in your timeline that are purple are linked.
    I usually leave this turned on, as its a great reminder when/why things are slowing down.
    Glenn
