Activity Forums DSLR Video Transcoding 5D to AppleProRes
  • Transcoding 5D to AppleProRes
    Posted by Anthony Derose on July 25, 2010 at 7:04 pm
    Quick question, when using MPEG Streamclip to transcode 5D h.264 files to apple pro res what does the frame rate (usually blank mean). I have tested it blank and then typed it 24 and motion looks the same. I assume its for converting to lower or higher fps and leaving it black to transcodes it as the default you shot it in (whether 24 with the 5D update or 30 non updated.)
    http://www.anthonyderose.com
    Chris Tompkins replied 16 years, 1 month ago 4 Members · 4 Replies
  • Chris Tompkins
    July 25, 2010 at 10:48 pm
    You put in the frame rate of your footage.
    This is Frames per second (FPS).
    Chris Tompkins
    Video Atlanta
  • Michael Sacci
    July 26, 2010 at 12:33 am
    The camera is not shooting true 24fps, it is 23.976fps or rounded to 23.98 fps.
  • Peter Enright
    July 27, 2010 at 4:54 am
    Rereading my question I realize I did not ask it well. I know the camera shoots at 23.98 and that the Frame box in mpeg streamclip means fps. What I meant to ask is when converting to pro res do i need to bother typing anything in that box? can i leave it blank? i assume that it will just convert to its native frame rate it was shot in if the box is left blank.
  • Chris Tompkins
    July 27, 2010 at 1:57 pm
    I always enter the frame rate of the footage to be converted.
    Chris Tompkins
    Video Atlanta
