Activity › Forums › Apple Final Cut Pro › Transcodes from RedcineX
Posted by David Hudson on July 22, 2015 at 3:25 pmWondering if anyone has done this: Transcode R3D files on a separate system (it has the Rocket card!) using redcineX to prores LTs? Then use those transcodes to edit, then to finish use relink to attach to the original R3D files.
I think this should work but I can’t get it to workoutJeremy Garchow replied 11 years, 1 month ago 3 Members · 5 Replies -
Oliver Peters
July 22, 2015 at 3:28 pm[David Hudson] “Then use those transcodes to edit, then to finish use relink to attach to the original R3D files.
I think this should work but I can’t get it to workout”This will work in Resolve, not in FCPX.
– Oliver
Orlando, FL
http://www.oliverpeters.com -
Oliver Peters
July 22, 2015 at 3:34 pmI take that back. I was able to get a relink back to the .r3d file. I had to manually point it to the REDCODE clip within the .r3d container. Otherwise, it defaulted to the matching QuicKtime.
– Oliver
Orlando, FL
David Hudson
July 22, 2015 at 3:40 pmSo you had to relink each clip individually, thats what I was finding. As soon as I tried a few at a time I couldn’t get it to relink. Bummer.
Oliver Peters
July 22, 2015 at 3:59 pm[David Hudson] “So you had to relink each clip individually, thats what I was finding. As soon as I tried a few at a time I couldn’t get it to relink. Bummer.”
Correct. That’s where Resolve does a better job of relinking.
– Oliver
Orlando, FL
Jeremy Garchow
July 22, 2015 at 5:10 pmSend an fcpxml from your prores timeline back to red cine x. RCX will relink back to the r3d.
Export a “shallow” fcpxml and import back to fcpx.
