Activity Forums Adobe Encore DVD transcode settings in Encore CS3 for 24 frames?
  • transcode settings in Encore CS3 for 24 frames?
    Posted by Nathan Quattrini on April 10, 2009 at 2:50 pm
    Ok so I exported my 3 short films (all 23.976) and then dropped them into encore. Used the “automatic” transcode settings, and burned a DVD. Looks like crap. I found I can make my own preset for transcoding, so what settings should I be using to make the video not jittery and blurry? Thanks
    Joe Bowden replied 17 years, 4 months ago 3 Members · 5 Replies
  • Jeff Bellune
    April 10, 2009 at 3:22 pm
    Encore won’t properly encode 23.976 fps video for NTSC DVD. Use Pr or a third-party encoder.
    -Jeff
    The Focal Easy Guide to Adobe Encore DVD 2.0
  • Nathan Quattrini
    April 10, 2009 at 3:53 pm
    Use premiere how? The only way I found so far was to export a 24 frame file, then open a new PR project with 29.97 frame rate, import the 24 video, turn off frame blending, then export as 29.97. Then put that video into Encore. I can`t burn straight to DVD since I have other videos etc to mix with. Is this the only way to do it?
  • Joe Bowden
    April 10, 2009 at 3:56 pm
    Did you do your editing in Premiere? If so, just open the sequence and export it to MPEG-2 as 24p.
  • Nathan Quattrini
    April 10, 2009 at 3:58 pm
    I did do it all in premiere. If I export as mpeg2 does it still need to transcode in encore? How will it control how to compress each separate video so they all fit on the DVD?
  • Joe Bowden
    April 10, 2009 at 4:54 pm
    Make sure you MPEG-2 settings are for 23.98 fps progressive.
    You’ll have to manually calculate your bit budget using this method. There are lots of online bit budget calculators…take a look at videohelp.com
