Activity Forums Adobe Encore DVD Transcode setting
  • Transcode setting
    Posted by Vegard Sorby on February 23, 2006 at 11:41 am
    Hi again, I’ve always used the ‘automatic’ setting, which has been on 4MB VBR 2 PASS, with good results. However, this last time (as it was a s16mm project), the quality seems noticably worsened in the transcoding process. I’m just wondering if there are any reasons why I shouldn’t manually choose the higher bitrate 7MB VBR 2 PASS? Will it be compatible with all players?
    Jeff Bellune replied 20 years, 7 months ago 2 Members · 3 Replies
  • Jeff Bellune
    February 23, 2006 at 12:47 pm
    Automatic transcode settings in Encore are moving targets, based on the amount of video material in a project. It’s not permanently set to 4MB or 7MB or anything else.
    Are you possibly referring to the default preset that appears when you open the Transcode Settings dialog?
    -Jeff
  • Vegard Sorby
    February 23, 2006 at 12:56 pm
    Ok, yes you are right, I assumed what was shown in the settings when I opened the dialog box was the ‘automatic setting’.
    So since I only have about 40min of footage altogether, I should just keep it on automatic, and it should be choosing the best settings for me?
    Cheers!
    Vegard
  • Jeff Bellune
    February 23, 2006 at 4:52 pm
    Yes. Encore’s automatic transcoding does a great job.
