Activity Forums Avid Media Composer Transcode RED 59.94 into a 23.976 project
  • Transcode RED 59.94 into a 23.976 project
    Posted by Geoff Klein on December 13, 2011 at 2:08 pm
    Hey guys,
    I’m trying to get a clip that we shot at 59.94 on the RED, into an AVID project at 23.976.
    We shot it at 59.94 so that it would make for a really nice smooth slow motion effect when played at 23.976.
    But whenever I bring in the RED file using AMA into the project and then transcode, it always ends up playing at normal speed.
    Any idea how how I can get the clip to play in smooth slow mo? When I view the clip in Red Cinex, it plays in slow mo, so I know it’s been shot properly; just can’t figure out how to get AVID to recognize it.
    Geoff
    http://www.bikinigirlsonice.com
    http://www.bgoifilms.com
    Bouke Vahl replied 14 years, 9 months ago 4 Members · 6 Replies
  • Shane Ross
    December 13, 2011 at 5:58 pm
    To quote Michael Phillips:
    “Import/capture material in a 1080i project. Open bins in the 23.976 project. When you cut it into the timeline, it will automatically be time adjusted to for 23.976 using the Mix & Match feature (v4 and v5). Once on the timeline, open the motion adaptor applied and change its speed to 1:1 rather than the adjusted rate. You will want to keep the interlace to progressive active. ”
    https://forums.creativecow.net/thread/45/878016
    Shane
    Little Frog Post
  • Geoff Klein
    December 14, 2011 at 1:39 pm
    Thanks for the response.
    So my last question is when I have my clip on the timeline of the 23.976 project, I basically open the motion effect that has automatically been applied to the clip, and then select “promote” option next to “motion adapter”… but then what?
    I don’t see the option to adjust the speed to 1:1…
  • Geoff Klein
    December 14, 2011 at 7:23 pm
    I figured it out. My source was 59.94p, not “i”, so I had to transcode into 720p 59.94 and then open then bin in my 23.976 project. It’s only my offline so the resolution change doesn’t make a difference.
  • Bouke Vahl
    December 15, 2011 at 2:49 pm
    Another option is to do a QT import.
    The console command ‘ignoreQTrate = TRUE’ will give you a slomo clip, as each frame will be a frame and thus the duration is altered.
    This way you don’t have any resolution trouble.
    Bouke
    https://www.videotoolshed.com/
    smart tools for video pros
  • Michael Hancock
    December 15, 2011 at 2:52 pm
    Bouke – do you have to strip the audio off the Quicktime first? I can’t remember if Avid ignores the audio and import only the video, or if you have to make the QT file video only or the console trick doesn’t work.
    Michael Hancock
    Editor
  • Bouke Vahl
    December 15, 2011 at 3:02 pm
    Good one. I must admit, i forgot…
    (was a long time ago i used this, and that was on an other version of avid than i run nowadays…)
    Trial and error it is. But a QT ref should work, is easy to make and alter…
    Bouke
