Activity Forums Adobe Encore DVD Transcode Question
  • Transcode Question
    Posted by Devon Allistone on April 6, 2005 at 9:36 pm
    Hello,
    I recently have switched over from using Impression DVD-Pro, (a Pinnacle product) to Encore. The Capture Card I am using to digitize the video is a DC2000, (another Pinnacle product) which captures DVD complient MP2 files. My question is, why is it that Encore thinks my captured Video/Audio files are not DVD complient and need transcoding?
    Any help would be greatly appreciated.
    Thanks in advance…
    Devon
    Devon Allistone replied 21 years, 5 months ago 2 Members · 4 Replies
  • Roadkill
    April 6, 2005 at 10:17 pm
    Devon,
    Could you check an MPEG-2 file made with the DC2000 with Bitrate Viewer and post the following info (found in the lower right):
    Stream type:
    Resolution:
    Aspect ratio:
    Framerate:
    Nom. bitrate:
    VBV buffer size:
    Chroma format:
    DCT precision:
  • Devon Allistone
    April 7, 2005 at 2:46 pm
    Hey,
    Thanks for the quick response.
    Stream type: MPEG-2 MP@ML VBR
    Resolution: 720*480
    Aspect Ratio: 4:3 Generic
    Framerate: 29.97
    Nom. bitrate: 6006000 Bit/Sec
    VBV buffer size: 112
    Chroma format: 4:2:0
    DCT precision: 10
  • Roadkill
    April 7, 2005 at 7:55 pm
    Devon,
    All the parameters you posted are DVD compliant. I half expected the DC2000 MPEG-2 to be 704×480 instead of 720×480 which would force Encore to re-encode. But I don’t see anything Encore could object to.
    Are the DC2000 files multiplexed (audio and video) or are they elementary (video only) streams? If they are multiplexed, the audio is probably MPEG-1 Layer II and Encore’s transcoding may be only for the audio part, not the video.
  • Devon Allistone
    April 7, 2005 at 8:06 pm
    Hey RK,
    The DC2000 captures the files seperately. The audio file is captured as a .wav file.
    Rate: 48000Hz
    Format: 16 Bit stereo
    Uncompressed
    Interleave: 1/2 Second
    If the audio needs transcoding, I don’t really mind. Audio only takes a moment, but waiting for video transcoding takes a very long time. (8 minutes for a 3 minute clip)
    If you have any other ideas i’d love to hear them. I’m currently stumped.
