Activity Forums Adobe Encore DVD Transcode quality
  • Transcode quality
    Posted by Tobias Van kleeck on October 18, 2013 at 4:03 pm
    Hello all, thanks for any help in advance! I am a novice at Encore and authoring in general so, bear with me, please.
    I realize that DVD quality is only 720×480 but, that said, the quality drop off from 1080 to 720 is so staggering (see image) that I feel like I must be doing something wrong… The transcode settings are pretty much the standard with the only difference being that I use the “Scale to fill” option.
    Hopefully this makes sense – any help is incredibly appreciated!
    -Toby
    David Rehm replied 12 years, 11 months ago 3 Members · 2 Replies
  • Daniel Ludwig
    October 19, 2013 at 10:41 am
    Tobi,
    SD NTSC is the worst TV standart ever made, so there is nothing to talk about.
    thank god, I´m living in PAL-land 😉
    one thing that might be possible is – if you have used 1440×1080 (nativ resolution), which is anamorphic HD1080, what will be interpreted as 1920×1080, than it´s possible that your downscaling will result like this.
    what´s your original source? HDV or AVCHD? HDV definitly is 1440×1080 and AVCHD could be 1440×1080 depending on your recoding-setting within your cam.
    danny
  • David Rehm
    October 29, 2013 at 3:30 pm
    The popular editors (Premiere, FCP, etc…) cannot produce pro quality images when downscaling to SD.
    Read this article – it not only explains why but also provides the answer on how to achieve the results you’re looking for – and it’s free.
    https://www.precomposed.com/blog/2009/07/hd-to-sd-dvd-best-methods/
    Here’s a follow up article
    https://www.precomposed.com/blog/2010/10/hd-to-sd-dvd-cs5-revisited/
    Also – here is Jeff Bellune’s tut/info on this same process
    https://bellunevideo.com/tutdetail.php?tutid=14
    https://bellunevideo.com/tutdetail.php?tutid=10
    The process will look like a hassle and probably overwhelming but it will save you much time in the long-run and you’ll have better results.
    Hope this help,
    David
