Activity › Forums › Adobe Encore DVD › Transcode Presets & Project Tab Info
  • Transcode Presets & Project Tab Info
    Posted by Calvin Dean on May 9, 2005 at 9:49 pm
    In the Project Tab, what is “Bitrate” referring to?
    Using the transcoding Presets, 9 is the maximum bitrate, 1.5 the minimum and 4 or 7 being the target (depending upon which present you select). Yet my bitrate says 9.2 according to the Project Tab information. How can this be? Am I interpreting this info correctly?
    Tim Kurkoski replied 21 years, 4 months ago 2 Members · 1 Reply
  • Tim Kurkoski
    May 11, 2005 at 2:54 pm
    If your file has both video and audio, the excess bitrate is for the audio. The transcode presets only refer to the video bitrates, but the total bitrate is what is reported in the Project window. Look deeper into the settings for the given preset, and you’ll find the audio bitrate- likely it’s 192kbps (or appx. 0.2Mbps).
