Activity Forums Avid Media Composer transcode, consolidate, or AMA audio files
  • transcode, consolidate, or AMA audio files
    Posted by Daniel Schultz on November 21, 2014 at 4:19 pm
    I’ve got a 3-camera, separate audio shoot I’m setting up for editing.
    The audio is from a sound devices mixer with 4 channels, and they are WAV files.
    On a previous shoot, I grouped the audio and video as multi-cams and it worked nicely.
    I would like to do the same here, and prefer, overall, to get everythign possible into MXF Avid-friendly format.
    Is there a way to transcode the raw WAV files from the mixer without turning them into video files?
    Or do I just transcode them the same way I do with video material?
    Also, is it better to transcode or consolidate in this case?
    I’m running MC 7.0 on a macBook Pro Retina.
    Thanks, Dan
    Sean Smith replied 11 years, 10 months ago 2 Members · 1 Reply
  • Sean Smith
    November 21, 2014 at 7:05 pm
    I would just import the WAVs. Also, if you rename them before you import, so they have numbered suffixes (filename_01.wav), when you import, that number will become the default track for the wav. This will apply to both autosequencing and grouping.
