Activity Forums Adobe Premiere Pro Transcode a sequence
  • Transcode a sequence
    Posted by Kristian Skogen on May 9, 2012 at 8:31 am
    I have a sequence in Premiere Pro that i want to transcode to Prores before sending it to Resolve.
    In Final cut i would use the Media manager, in Media Composer i would right click and transcode the sequane and in premiere i would….?
    Kristian
    Francois Driessen replied 13 years, 6 months ago 4 Members · 4 Replies
  • Shane Ross
    May 9, 2012 at 2:12 pm
    Use the PROJECT MANAGER. In the PROJECT menu.
    You must have some Final Cut studio component for this to happen. FCP, or Compressor, or Motion. Or I think the ProRes codec is downloadable from the App Store.
    Shane
    Little Frog Post
  • Kristian Skogen
    May 9, 2012 at 2:39 pm
    Where in the Project Manager can i choose codec?
    Kristian
  • Matt Harris
    August 15, 2012 at 10:06 am
    Same problem here, no way to choose the codec in Project Manager. any answer?
  • Francois Driessen
    January 31, 2013 at 4:48 pm
    Yep. No trans-coding options. Only duplicating media.
    But that means you have all your used clips in a folder – which you can then batch encode through an external encoder like Compressor / Clip Wrap if you’re wanting to go MTS to MOV. Re-Link and you’re good to go.
    Anyone found any internal PP solution yet?
    Francois
    FireTrigger Inc.
    https://firetrigger.com
