Activity Forums Drones/UAV Training A Drone Spotter
  • Training A Drone Spotter
    Posted by C. blake Davis on March 23, 2017 at 12:49 pm
    Hello all, I’ve just started working with a company that does a lot of drone videography.
    According to the laws in our state we require a ‘drone spotter’ while operating in certain areas.
    They plan for me to start working as a spotter, so I wanted to train myself a bit, but can’t find anything related to my requirements or how to do it well (I assume the basics are “Make sure they don’t hit anything”).
    Any recommendations of what makes a good spotter, or materials you can send my way?
    Producer working in NorCal and Nashville
    Rich Rubasch replied 9 years, 1 month ago 3 Members · 2 Replies
  • Jennifer Pidgen
    March 23, 2017 at 6:35 pm
    A visual observer (as they are known by FAA regulations) must adhere to the same guidelines as the Pilot in Command (PIC).
    From §107.27:
    • 8 hours from “bottle to throttle” (no drinking of alcohol within the last 8 hours),
    • do not fly while under the influence of alcohol, including a hangover,
    • do not fly while using any drug that may adversely affect safety,
    • alcohol concentration below 0.04 in a blood or breath specimen.
    From VLOS (§107.27) and VO (§107.33)
    The aircraft must always be within visual line-of-sight (VLOS) of:
    • The remote-PIC and the person operating the drone, or
    • A visual observer (VO)
    • VLOS means the aircraft is close enough to be seen without any aid such as binoculars (Contact lenses or glasses are excluded) .
    Visual Observers should always be in communication with the PIC….if they are not standing side-by-side, then use of radios would be necessary. Some of the key responsibilities of the Visual Observer:
    • Maintain VOLS with the aircraft
    • Ensure that no other aircraft or no other people on the ground enter your area of operation
    • Continuous communication with PIC on position, altitude, attitude, and movement of the sUAS
    • Is it hovering? Is it actually moving left vs. right? Is it shifting direction with the wind? Is it getting too close to a hazard/obstacle?
    • Has another aircraft been spotted in the vicinity? If so, should the sUAS be grounded?
    • If the aircraft is tasked to “return to home” (usually when something goes awry) ensuring communication to get the aircraft back safely
    Bottom line, you’re right, it is applying a lot of common sense in ensuring the safe flight of your sUAS operation. The visual observer’s role is to “See and Avoid” and maintain a lookout for other potential hazards that may affect the safety of flight.
  • Rich Rubasch
    August 11, 2017 at 9:07 pm
    Don’t take your eyes off the thing….
    Rich Rubasch
    Tilt Media Inc.
    Video Production, Post, Studio Sound Stage
    Founder/President/Editor/Designer/Animator
    https://www.tiltmedia.com
