Activity Forums Adobe After Effects Expressions trails with position variables
  • trails with position variables
    Posted by Christine Edwards on March 14, 2011 at 4:38 pm
    I have a white ellipse that enters screen left and exits screen right (basic animation here:https://www.youtube.com/watch?v=jUIgcULk9n8)
    I’ve plugged this script into the position expression:
    strt = 0; //start time of template motion
    end = 4.0; //end time of template motion
    t = thisComp.layer(“template”);
    offset = (t.effect(“offset”)(“Slider”)/100)*(index -1);
    travel = linear(t.effect(“travel”)(“Slider”)/100,strt,end);
    t.position.valueAtTime(travel – offset)
    I got this script from:https://www.motionscript.com/mastering-expressions/follow-the-leader.html
    under “Follow the Null”
    this script is working well, but I want to add follow the nulls z rotation and also make a “spread” slider so that I can spread my white ellipses so that they aren’t all in one train line.
    sorry if this is a FAQ but I can’t find my exact situation and I’m not good with expressions to design or modify!
    t = thisComp.layer("template");
    offset = (t.effect("offset")("Slider")/100)*(index -1);
    travel = linear(t.effect("travel")("Slider")/100,strt,end);
    t.position.valueAtTime(travel - offset)
    Dan Ebberts replied 15 years, 6 months ago 2 Members · 1 Reply
  • Dan Ebberts
    March 14, 2011 at 7:55 pm
    You can adapt the expression to z rotation like this:
    t.transform.zRotation.valueAtTime(travel - offset)
    I’m not sure what you mean by “spread”. Can you be more specific?
    Dan
