Activity Forums Adobe After Effects Trailer to film “Abandoned” – text treatment advice needed??
  • Trailer to film “Abandoned” – text treatment advice needed??
    Posted by Mike Bohatch on January 11, 2008 at 5:06 pm
    I was wondering if someone had any advice on how to achieve the title treatment they use in the film “Abandoned”?
    I’ve tried different plugins but just cant seem to get that “specific” look
    For reference the treatment i’m speaking of is the end of the taglines later in the trailer where the text “smears and explodes in small portions” (almost looks like smeared dust).
    it actually looks like clever smearing effect
    (its seen best at the 1:05 mark)
    I’ve tried shatter, roughen, and liquify but just cant get correct feel they use.
    Which seems to be a bit more organic
    Here is the URL of the trailer for reference:
    https://www.apple.com/trailers/independent/theabandoned/trailer/
    Any advice appreciated!!
    Mike
    Darby Edelen replied 18 years, 8 months ago 3 Members · 3 Replies
  • Antony Buonomo
    January 11, 2008 at 6:42 pm
    Explore: directional blur, Trapcode Shine, roughen edges, changing between two typefaces and animating the scale/character tracking. That should get you close – It doesn’t look too complicated.
    Often I think (generally, not aimed at you) the mistake is in expecting that there will be one effect or commercial plugin that will reproduce something that you have seen. Mostly, it was probably achieved by a designer/artist playing around and combining effects until they arrived at something they liked (or the deadline hit).
    Also, question yourself on why you would want to reproduce something that someone else has done. Fine, if you are doing it to learn, equally fine if it’s a starting point for your own vision; but as an end in itself? I hope not.
    Good luck – and I didn’t intend to embark on a lecture!
    A
  • Mike Bohatch
    January 11, 2008 at 6:51 pm
    Thanx for the tips, yes wanting to learn the method so I can apply it further or for enhancing a specific feel – often I’ve found trying to de-engineer provides a learning experience in itself that opens strange new options that otherwise may not have been apparent
    M
  • Darby Edelen
    January 12, 2008 at 7:22 am
    I would suggest first creating some fractal noise and animating the evolution. Then bring this fractal noise comp into another comp where you can create your text. Try applying Gradient Wipe, Displacement Map and Compound Blur to your text, set all of them to use the fractal noise comp as input and play with the properties… For bonus points create different fractal noise comps with different looks and use them to drive the different effects (small and ‘torn’ looking fractal for Gradient Wipe? large blurry fractal for Compound Blur?).
    The rays of light shooting out of the text can be achieved with Shine, as discussed, or a radial blur set to ‘zoom.’
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
