Activity › Forums › DVD Authoring › Tracks with different aspect ratios
  • Tracks with different aspect ratios
    Posted by Sarah soquel Morhaim on October 16, 2009 at 12:38 am
    Hello,
    I had a question about the capabilities in DVD Studio Pro 4.0 concerning the following scenario- if you have a dvd project built with a menu leading to several video tracks, some of which are 16:9, some of which are 4:3, is there any way to ensure that ALL the tracks play in correct aspect ratio in both wide screen AND 4:3 TVs? as in, on a widescreen tv the 16:9 videos would fill the frame and the 4:3 videos would have black bar on the sides. and the same DVD on a 4:3 tv would have the 4:3 videos filling the frame and the 16:9 videos playing with letterbox. besides setting the aspect ratio of the track correctly (which does make the tracks play in correct aspect ratio when the DVD being viewed in a laptop, but not a tv in my experience) is there some way to flag the tracks in Studio Pro to make this happen? or is this pipe dream?
    also, if you have tracks where some are 16:9 and some are 4:3, what’s the best way to have a “PLAY ALL” function, in addition to a menu where tracks are selected individually that end jump back to the menu? the only way I’ve thought of to do this is to duplicate all the tracks in the project, and in the second group link the PLAY ALL button to first track, then connect the rest through end jumps. seems silly to double the content, plus can fill the disc up past capacity.
    any guidance is most appreciated,
    sarah
    Sarah soquel Morhaim replied 16 years, 11 months ago 5 Members · 6 Replies
  • Noah Kadner
    October 16, 2009 at 2:54 am
    That should pretty much happen naturally- if you set up your aspect ratios correctly the DVD player itself will do the proper letterboxing/pillar boxing and full framing as needed for both 4:3 and 16:9 displays…
    Noah
    Check out my book: RED: The Ultimate Guide to Using the Revolutionary Camera! Unlock the secrets of 24p, HD and Final Cut Studio.
    Now featuring the Sony EX1 Guidebook, Panasonic HVX200, Canon EOS 5D Mark II, and Panasonic DVX100.
    Call Box Training
    DSLR Cinematography Blog
  • Andrew Saliga
    October 16, 2009 at 8:39 pm
    DVDSP should do this automatically as Noah says. One tip I’d add is to make sure that there is a frame or two of black at the beginning of these tracks or the video itself. I’ve had the track start on a freeze frame of sorts while the DVD player switches to play at the correct aspect ratio.
    For example, if creating a “play all” option, going from a 4:3 track to a 16:9 track may result in a a short lag where the 16:9 video is displayed at 4:3 before correcting.
    Also note that 16:9 DVDs should letterbox on a 4:3 set and be full screen on a 16:9 set, but the major gotcha on this one is that this is a feature on most DVD players that must be activated via menu. Hopefully everyone realizes to enable this function on their DVD players, but I’ve realized most people don’t even notice when their TV images are distorted, know to adjust settings on their TVs, yet alone within the DVD player.
    -Andrew Saliga
    Steelehouse Productions
    http://www.steelehouse.com (undergoing a much-needed redesign)
    http://www.vimeo.com/steelehouse
  • Christopher Smith
    October 17, 2009 at 2:37 am
    [Sarah Soquel Morhaim] “what’s the best way to have a “PLAY ALL” function, in addition to a menu where tracks are selected individually that end jump back to the menu? … seems silly to double the content, plus can fill the disc up past capacity.”
    Sarah,
    Your second question hasn’t been answered yet. You have videos of different aspect ratios, so you can’t make them chapters of one track, and then create multiple Stories, one that plays all of them, and others that play one chapter and return to menu.
    So, you will have to create scripts. When the user selects Play All, they are sent to a script that sets a PlayAll flag & then jumps to Video_1 (track). Each track has as its End jump to go to a script which checks for this flag.
    Video_1 (a track) end jumps to Video1End (script)— if PlayAll = 1, jump Video_2 (track). If PlayAll=0, jump to Menu:whatever_button_you_want_highlighted
    Video_2 (a track) end jumps to Video2End (script)— if PlayAll = 1, jump Video_3 (track). If PlayAll=0, jump to Menu:whatever_button_you_want_highlighted
    Actually, you could put all the Video track end jumps into one script, and set a WhichVideo flag in a prescript for each track. It just depends on your programing style, whether you like lots of little scripts, or fewer large ones with lots of condition statements!
    Christopher Smith
    CBN WorldReach
  • Eric Pautsch
    October 18, 2009 at 4:02 am
    No need to script this at all. Actually using stories is perfect for this siutaion and also how most professional disc would be authored. The stand alone track would be the individual piece while a story of the same track would be apart of the play all. Once a story is created its a self contained title with its own end jump.
  • Christopher Smith
    October 18, 2009 at 5:23 pm
    Thanks, Eric. Each video, itself a track, would have a single-entry story. Play All button plays Track 1:Story, which end jumps to Track 2:Story, etc. Thanks for giving us a new way of looking at stories.
    Christopher Smith
    CBN WorldReach
  • Sarah soquel Morhaim
    October 28, 2009 at 4:07 am
    Thanks for all the answers!!
    (and apologies for taking longer than i’d like to say thank you.)
