Activity Forums Adobe After Effects Tracking_text and Ancor_point
  • Tracking_text and Ancor_point
    Posted by Arthur489 on October 22, 2007 at 1:47 am
    Hi , I set the ancor point of my text in the center, then apply to my text:animate>tracking.K_frame on tracking amount to 0.Then 5 frame foward K_frame set to 6.My Text start tracking but from the left(like if he do not register the previous ancot point setting)Where I’m wrong? sorr my english
    thanks
    Arthur
    Arthur489 replied 18 years, 11 months ago 2 Members · 2 Replies
  • Mike Clasby
    October 22, 2007 at 2:03 am
    Yes, oddly, moving the anchor point (with the Pan Behind Tool) does not change where the tracking animates from. But if you set the Paragraph (Ctrl 7) to Center Text (second on the right in the Paragraph Palette), then it will track from the center.
    Oddly enough it looks like the anchor point is moved to the center (that little circle with the x in it), although the numbers for anchor point don’t change.
    So use Centered Text.
  • Arthur489
    October 22, 2007 at 3:18 am
    thanks yikesmikes,
    for your Very/Fast answer, yes that was the solution….so simple—I spend few hour checking eveything, prefernces and stuff like that, and the center text _btn was i front of me….
    uuuuuuuuuhhhh !!!
    Thanks again
    Arthur
