Activity Forums Adobe After Effects Tracking question : rotobrush and frame hold
  • Tracking question : rotobrush and frame hold
    Posted by Hanna Dean on May 12, 2016 at 11:26 pm
    just to make this topic simple i will say i have a 10 seconds clip of a bus with a text in front of it , i have mocha 4 corner pin data and now on frame ( 1 ) i use clone tool to remove the text and now its looking good , how do i use this current cloned frame for the rest of the frame because when i skip forward to next frame text comes back.
    i just mentioned the video being 10 secondsa and yes 10 seconds is very easy to keyframe it but ,what if the frames more then 100, then we talking about wasting alot of time here , so am seeking advise is there are better approche for this trick using either standard track data or 4 corner pin
    Hanna Dean replied 10 years, 4 months ago 55,435 Members · 3 Replies
  • Hanna Dean
    May 13, 2016 at 10:05 am
    thanks for the kind reply il update you with video asap should have done it in first place
  • Hanna Dean
    May 13, 2016 at 10:11 am
    i can use this method on a still object but on a moving object as a airplane rolling down to park cannot do it on cause its on the move and the text comes back because the next frame isnt being effected by clone.
    i cloned stamed 1 frame then used freeze frame and pick-wipped that to tracking null it holes but as it moves you can se it doesnt look like because u can se something on top of it maybe needs proper blending in.
  • Hanna Dean
    May 13, 2016 at 10:32 am
    am basicly trying to do similar to this video
    https://www.youtube.com/watch?v=UHde2_WPr2w
    but its moving object and it has alot of frames so doing it all manual can take days , i needed a tracking method way , as i said i tested on still object it works with tracking data but not with moving.
