Activity › Forums › Adobe After Effects Expressions › Tracking Problem
Tracking Problem
Posted by Staeff on November 29, 2006 at 4:53 pmI’m trying to track a camera pan to animate some clouds for the scene. Because my pan is about 180
Staeff replied 19 years, 10 months ago 3 Members · 3 Replies -
Mylenium
November 29, 2006 at 7:09 pmWell, you are switching tracking points and that’s all that needs to be said. By cahnging the tracking points, you effectively cahnge the angular relation and in that case you simply cannot expect to get proper results. Split up the clip or track all trackers at once, than calculate your rotation by averaging their values using expressions. You can of course use alternative tracking tools such as PFHoe that support extrapolation of brocken track paths and try your luck.
Mylenium
[Pour Myl
Tony Kloiber
November 29, 2006 at 10:25 pmIf you track rotation you can’t change your tracking positions as you have. A different spot on the same circle is traveling in a different vector (direction) than any other spot on that circle, even if sooner or later they move through the same points in space it happens at a different time.
The sample clips show a chimney. The left and right sides of that object would be the best bet.
Good Luck
TonyTony
Staeff
November 30, 2006 at 7:29 amThanks Mylenium,
and greetings to Leipzig from a former Dresden-boy. 🙂Thanks also to TonyTony.
Stefan
