Activity Forums Adobe InDesign Tracking problem
  • Tracking problem
    Posted by Jeff Cochran on November 3, 2011 at 7:41 pm
    Hello,
    I’m having an issue when I kern or track copy in InDesign. When I try to track a line of text in the middle of a paragraph, often times InDesign will change the text above the line I’m working on (as in rolling part of the line down a line). Is there any way I can fix this so when I kern a line of text it doesn’t change any text above the line I’m working on?
    Thanks in advance.
    Jeff
    Dwayne Smith replied 14 years, 9 months ago 2 Members · 1 Reply
  • Dwayne Smith
    November 8, 2011 at 9:45 am
    G’day
    In CS2 you would open your paragraph panel and choose Single Line Composer from the dropdown menu. This is a paragraph level preference, so you only need to have your cursor somewhere within the paragraph to change the composer preference.
    I guess it’s something similar in other versions too.
    Hope that’s what you’re looking for.
    m.
