Tracking & Parenting Question
Hi Everybody,
Quiet a while since I used following workflow, so I forgot some parts. Need some help here:
As you can see in the image, I want to insert the Pre-Comp Footage of the TV content into the moving TV (the two guys dancing with it).
The tracking worked fine (including scale tracking since the TV moves forward and backward also).
Then I applied the data to a Null Layer and I parented my TV Screen footage to the Null, both the Position and the Scale.
It moves perfectly with the movement of the TV, just that the Scale and basic starting position are totally offset (see image).
How can I adjust scale and position on the starting frame to match the TV’s position?
Thanx.Greetings,
Sascha Engel
TIME BANDITZ Productions
http://www.youtube.com/taikang
